Trans Temp sender question...
Old Apr 24, 2010 | 05:45 PM
Brown Falcon's Avatar
Brown Falcon
How is the actual sender wired up?
The previous owner of my truck had the sender plumbed into a soft line near the tranny cooler. Had one wire hooked up to it going to the gauge, and had another wire with a 12v source ending at the sender also.
How are yours wired? Is there just one wire from the gauge? Or is there also a power wire going to the sender?
Old Apr 24, 2010 | 06:40 PM
jleal_21's Avatar
jleal_21
i too have wonted to know how these things work cuz i have one in my truck but it stop working for some reason. i have wondered if a wire came loose or what but since i dont know how everything is wired i cant really tell.
Old Apr 24, 2010 | 07:57 PM
DRRXR's Avatar
DRRXR
What type do you have?
Here is some autometer info.
Diesel Truck Tips - Auto Meter Tech Tips has ifo on the tubing connect and the pressure test port
eGauges.com: Auto Meter Tech Tips
http://www.autometer.com/download_instruction/100v.pdf
Old Apr 25, 2010 | 08:47 AM
Brown Falcon
Thanks for the links Rocky... but didn't have what I needed.
I'm not even sure what brand gauge it is, it was there when I bought it. I'll look and see what it is and check their website and maybe I can figure it out.
For now I just have the wire from the gauge hooked up to it. Took off the 12v power wire going to the sender before.
When I drive to work tomorrow I'll see if it's actually still working and if not I'll hook up that power wire again.
