Trans temps
Old Apr 23, 2010 | 03:54 PM
ford4lifer's Avatar
ford4lifer
Question Trans temps
I have 120k miles on my truck and recently had the trans serviced, fluid and exterior filter replaced. I had the first service done around 50k miles. Since the service it seems my temps have been higher than normal, creeping up to 165 unloaded and up to 180 loaded in town. It cools back down after about 5 mins of idling. Today's temps were 80 deg. I don't remember it doing this before. Is there something I need to check or have checked? The dip stick is just below the full hot mark and the fluid is clean, haven't had any shifting or any noticible problem with the trans ever. Is this normal or should I be worried? At what temp should I start to really worry?
Old Apr 23, 2010 | 04:28 PM
npccpartsman's Avatar
npccpartsman
The thermostat doesn't start to open until 165*. 180 is quite normal. According to our resident transmission engineer/expert you shouldn't worry until around 230* so you are quite fine.
Old Apr 23, 2010 | 05:14 PM
69cj's Avatar
69cj
On a side note; You should service the tranny every 30,000 miles, not 50,000.
Old May 3, 2010 | 12:53 PM
ford4lifer's Avatar
ford4lifer
Also if the trans has too much fluid in it would this cause it to read higher temp?
UNTAMND
Jan 10, 2012 04:25 PM
Shake-N-Bake
26
Jul 4, 2010 02:16 PM
Dezertracer
May 4, 2008 04:52 PM
shorebird
Jul 29, 2007 02:04 PM
Schmavic
Offroad & 4x4
22
Jun 5, 2004 11:52 PM
