02 7.3 deisel
Old Apr 23, 2010 | 07:23 AM
russkinnard's Avatar
russkinnard
02 7.3 deisel
started truck this morning and made it 20 feet and died. now its turning over fine but wont start????
Old Apr 23, 2010 | 07:43 AM
riverrat41's Avatar
riverrat41
Did you open the fuel bowl drain to see if you have fuel coming out the tube with the key on?Can you hear the fuel pump running?May need to check fuse #30.This is the fuel pump fuse.
Old Apr 23, 2010 | 07:57 AM
russkinnard
i opened the drain twice and fuel drained out. and checked fuse. do u know where the camshaft possition sensor is.
Old Apr 23, 2010 | 08:48 AM
bama29fan's Avatar
bama29fan
someone on here has pics of where it's located and what it looks like...
bump
Old Apr 23, 2010 | 08:50 AM
bama29fan's Avatar
bama29fan
heres a link...
Welcome to guzzle's CPS R&R Web Page<
Old Apr 23, 2010 | 09:29 AM
riverrat41's Avatar
riverrat41
If you are looking at the water pump,it is on the block on the left hand side of the water pump.You can see the wire going to it and it has a fin on the CPS....10MM bolt
