Center console disassembly
Old Apr 22, 2010 | 03:14 PM
superduty4x4's Avatar
superduty4x4
Has anyone been successful at disassembling this stupid thing without breaking the retaining clips? Lots of loose change in mine, I can't even open the door for the storage bin all the way. Its on there nice and tight and I really don't want to break any of those retainers if I can help it.
Old Apr 22, 2010 | 05:56 PM
strokersace's Avatar
strokersace
I've never done it. Tried it one time a few years ago but started to break some clips and quit.
Sorry no help but here's a bump.
Old Apr 22, 2010 | 07:02 PM
kawa's Avatar
kawa
Talking
On my Ranger there are four (4) screws on the bottom of the inside floor that will allow you to remove the innards. I can't recall for sure if you have to pull up the cloth on the bottom or ifI just found the heads ond unscrewed them.
Hope this helps.
Rog
Old Apr 23, 2010 | 10:45 AM
offrdmania's Avatar
offrdmania
I am actually tackling this today with the one from my 97 F250. Its going to be a slow process, I am going to take my time and make sure I find out exactly how it comes apart. Ill try to take pictures as I go.
Old Apr 23, 2010 | 10:53 AM
offrdmania's Avatar
offrdmania
I will tell you right now, there is no way to get that top off without breaking the clips. I read on another forum that those tops were meant to never come off. There is a platform just behind the cup holders that once I clean out the change I am going to put a couple pieces of 3M double sided tape to hold it down. Gently lift up on the lid and it will start to come up. I cleaned out the change in about 2 minutes and it is already back together
Old Apr 23, 2010 | 01:39 PM
offrdmania's Avatar
offrdmania
BTW, im selling a gray jump seat/center console if anyone is interested
Old Apr 23, 2010 | 07:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
There is an article in the Baz pages, I tried to follow it, but with no luck, I broke the retaining clips, and I jus install a pair or black screws in the upper front part of the lateral sides of the console, similiar to thouse used in some parts of the dash (self drilled), and was OK for me, next time when I need to disassembly, peace of cake.
Old Apr 23, 2010 | 07:58 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I used like this ones but in black:
Old Apr 23, 2010 | 08:01 PM
offrdmania's Avatar
offrdmania
when I pulled mine up only about half the clips broke so it snapped back down into place. No need for screws, it was tight
Old Apr 24, 2010 | 08:15 PM
superduty4x4
Bah. I WILL figure out a way to disassemble that bugger without breaking something! If someone would be so kind as to snap a pic of where the lock tabs are and what they look like I would be greatly appreciative.
Old Apr 25, 2010 | 11:52 AM
offrdmania's Avatar
offrdmania
they are plastic hooks that snap into holes, any upward pressure and they break off. I tried for hours to see if I could get a screwdriver in there to press them back but they are too low.
Old May 10, 2010 | 12:19 PM
superduty4x4
Another bump for photos of where the retainers are located. I still need to get mine apart and cleaned out.
Old May 10, 2010 | 02:31 PM
offrdmania's Avatar
offrdmania
Im not pulling it up again but there are 2 under the front rail, one on either side of the cup holders, 2 more equally spaced down the side and 2 on the back rail. I didnt even pull out the back. Just hinged the front up to pull out the change.
Old May 10, 2010 | 05:42 PM
pjwoolw's Avatar
pjwoolw
Well I will expect to see pics posted when your done!
Old May 12, 2010 | 09:56 AM
superduty4x4
Well... I tried and failed... miserably. Pete if you get ambitious and try to do this w/o breaking anything the only advice I can give you is you will need a pick with a long but stout end on it. The retainers on the upper cover protrude about 1/2" or so into the console itself and you will need something that can reach down in the hole and try to pop them loose. I ended up breaking all the retainers off before I was able to see good enough to figure out what was going on. I tried pulling on the retainers with a pick slid under the top piece of the console but couldn't get them to budge. A little E6000 adhesive smeared around... its not going anywhere now, retainers or not!
I had 3 retainers along the front edge and down each side FWIW.
