Bedliners
Old Apr 22, 2010 | 03:09 PM
Rocketattack's Avatar
Rocketattack
Bedliners
Will a bedliner from an '06 F350 fit a '94 F350? I have the chance to get a free bedliner for my truck and need to know if it will fit?
Old Apr 22, 2010 | 03:15 PM
TorqueKing's Avatar
TorqueKing
Get a spray-in. That's the only one that won't set you up for rust down the road.
Old Apr 22, 2010 | 06:03 PM
rmeyer001's Avatar
rmeyer001
I bought a used bedliner at a local junk yard for $15.00. They only had one over the rail, which I wanted, and many under the rail. I just had to remove it and drag it to the front. Compared to $160 new or who knows for a spray in, it was a no brainer for my 94 F150. Good luck!
Old Apr 22, 2010 | 10:24 PM
TexasGuy001's Avatar
TexasGuy001
I doubt that is going to fit. I would recommend staying away from those plastic bedliners anyway.
The only bedliner I will have anything to do with is a rubber bed mat.
Old Apr 23, 2010 | 01:07 AM
nighthawk283's Avatar
nighthawk283
If it the same size bed then yes go for it, but if not then you may still be able to but you might have to squeak it on.
hope this helps
