No Speedometer!
Old Apr 22, 2010 | 09:06 AM
jt371's Avatar
jt371
______
No Speedometer!
I know this has been covered before., but can not find itthrought the search function. My friend has a '00 7.3 auto. His speedometer stopped working, OD light flashing, and ABS light on. I thought I read on here before that it may be a fuse.
Thanks
Old Apr 22, 2010 | 09:08 AM
just another truck's Avatar
just another truck
I dont know about a fuse, but the VSS is on the Rear axle.
Old Apr 22, 2010 | 09:13 AM
jt371's Avatar
jt371
______
I know that the VSS would be the other direction to look. I can look at tonight when I get home, but I am at work now. I was just trying to get him a direction to look.
Old Apr 22, 2010 | 09:22 AM
tws1616's Avatar
tws1616
I don't know too much about these trucks just yet but, my speedo quit working and I developed a leak at the pinion seal. Come to realize my vent hose was stopped up pretty good. I cleaned it out and no pinion seal leak and my speedo started working again. The clogged vent and speedo are probally not related, but just a thought....
Old Apr 22, 2010 | 09:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would check what Pat said. Napa calls this sensor a ABS sensor. Thats why your ABS light is on.
Old Apr 22, 2010 | 12:15 PM
BillyBob69's Avatar
BillyBob69
There are two sensors. One on the tranny and the other on the rear diff. Depends on what your truck is set up with. The rear diff sensor, (VSS), is the easiest. Some have been able to clean theirs and be fine, but for the most part, it is better to just replace it. It isn't expensive....usually about $15 to $17. Quick and easy to change out too.
