Pryo install Question
Old Apr 21, 2010 | 09:20 PM
bigblockford_390's Avatar
bigblockford_390
I just received my new pryo for my 6.9/turbo engine swap project. The engine is on the stand so I have complete access to everything so where is the best place to put the sensor/probe?
Jeff
Old Apr 21, 2010 | 10:13 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Drivers side behind/after #8.
IMNSHO!
-Enjoy
fh : )_~
Old Apr 22, 2010 | 10:03 AM
rodneywar's Avatar
rodneywar
what he said!!!
Old Apr 22, 2010 | 05:28 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I have to put one in the motorhome this summer. But still have no damn idea where to put the gauge! I hate the look of any after market gauges sitting on my nice old brown vinyl dash!
Old Apr 22, 2010 | 05:38 PM
peruses's Avatar
peruses
I like to mount my most important gauges up on the a pillar where they are in my feild of view
Old Apr 22, 2010 | 07:41 PM
bigblockford_390
Here is a picture for future reference for people installing a pryo sending unit on the 6.9/7.3 diesel. I am sure glad I installed it now before the engine was installed in my pickup.
Now I need to figure out where to mount the pryo gauge and boost gauge. I wish someone made a pillar mount for the older pickups as that would be the ideal place to mount them. Maybe I can fab something up myself to mount it on the pillar and still look good. If anyone has any ideas and pictures send them my way!
Jeff
Old Apr 22, 2010 | 07:58 PM
ford12508's Avatar
ford12508
So how did you get that installed, did you just drill a hole in the headers? Did you have to thread the whole somehow?
Old Apr 22, 2010 | 08:11 PM
swooshcmk's Avatar
swooshcmk
Is it 1/8" NPT standard on pyros?
Old Apr 22, 2010 | 08:18 PM
bigblockford_390
I did just drilled a hole, three steps up to a final size of 7/16. I then used a 1/4 pipe tap to thread the hole. I have a complete tap and die set along with a complete drill set so it was very easy to do, especially since the engine was out of the pickup.
You can buy the tap at a local parts store, hardware store, home depot ect and it tells you what size hole to drill before you tap the hole.
Jeff
Old Apr 22, 2010 | 08:20 PM
Festus Hagen
Methanoholic
Yes, it's drilled, then tapped.
Is that location going to interfere with anything in the engine bay???
-Enjoy
fh : )_~
Old Apr 22, 2010 | 08:21 PM
bigblockford_390
Mine was 1/4 NPT, but I do not know if that is standard or not.
My gauge was from VDO. Other makes might be different but im not sure.
Jeff
Old Apr 22, 2010 | 08:37 PM
bigblockford_390
-Enjoy
fh : )_~
I don't think so, but i will find out soon. Worse case is I put a pipe plug in and relocate it.
I for see attempting to put the engine in, to mark where I need to modify the fire wall to clear the turbo down pipe ect, and then pulling it out to make the needed changes. So I will know at that time if it will be in the way.
Jeff
Old Apr 22, 2010 | 08:44 PM
Festus Hagen
Methanoholic
And another chance it breaks ... :-)
-Enjoy
fh : )_~
Old Apr 23, 2010 | 12:26 AM
wreckinball's Avatar
wreckinball
you can also drill a hole and weld a nut on the tube if you dont want to buy a tap and die set. figured i paid for the welder, might as well use it.
Old Apr 23, 2010 | 07:50 AM
JoeyB94's Avatar
JoeyB94
I mounted mine almost directly on the last cylinder on the drivers side and didnt tap the hole. Its not leaking or anything either.
