Help!
Old Apr 21, 2010 | 04:56 PM
red rock 78's Avatar
red rock 78
Help!
I am looking for the best way to change my distributor bye myself? Turn the crankshaft manually to get tdc and rotor button to #1 and then mark it?Any feedback would be appreciated I have never changed one before.
Old Apr 21, 2010 | 05:03 PM
Hickfied's Avatar
Hickfied
Pull the number one plug. Rotate the crank with a 15/16" socket with your thumb in the sparkplug hole until you feel compression. Keep turning the crank until your timing pointer lines up with 12*BTDC on the balancer. Remove your distributor cap and the rectifier for #1 should be lined up with the pick up.
remove and install new distributor with the number 1 rectifier lined up with the pick up.
Old Apr 21, 2010 | 06:06 PM
TCB-1's Avatar
TCB-1
Make sure U get the correct wires on the correct spot on your new cap..
