Fuel issue
Old Apr 20, 2010 | 11:13 PM
Rider15's Avatar
Rider15
Fuel issue
1989 F-250 Lariat, Dual tanks. Front tank shows full however when selected truck dies. Filter issue or something else?
Old Apr 21, 2010 | 07:52 AM
subford's Avatar
subford
Check to see if your front in-tank fuel pump runs when you switch to it.
Old Apr 21, 2010 | 05:28 PM
Rider15's Avatar
Rider15
How do I do that? Have not worked on older trucks in a long time.
Old Apr 21, 2010 | 06:11 PM
subford's Avatar
subford
You can select the front tank, take the fuel cap off and listen while someone turns on the key. You should hear it run for one second each time the key is turned on. You might have to unplug the frame pump if the frame pump makes too much noise. That way you will know that you are hearing the right pump.
true blue
Nov 8, 2014 04:48 PM
esuitter
Electrical Systems/Wiring
Sep 6, 2014 10:23 PM
Iantiler
17
Feb 8, 2014 01:30 AM
MrRangerMike
1983 - 2012 Ranger & B-Series
Oct 7, 2013 10:33 PM
JasWood
Aug 5, 2010 02:27 PM
