Need help! Maybe?
Old Apr 20, 2010 | 10:13 AM
TN97STROKE's Avatar
TN97STROKE
Need help! Maybe?
2001 fresh oil, new cps, runs like a top. I have noticed setting at idle there seems to be a very small miss or shake to the truck....it is not steady it will do it for a second or two the stop then in a second or two do it again. The tach does not move but it feels like the rpm's drop then rise then drop. I have no check engine light on. It does not seem to effect the truck running just something I feel. Thanks for any help.
Old Apr 20, 2010 | 10:39 AM
clux's Avatar
clux
You might peek under the hood when it does it and see if it is your air conditioner compressor cycling on and off. The pcm cycles it periodically even when ac is off just to keep things working.
Old Apr 20, 2010 | 10:52 AM
BillyBob69's Avatar
BillyBob69
What CLUX said.
If that isn't it then I would take a look at the UVCHs and make sure they aren't coming loose.
Old Apr 20, 2010 | 10:56 AM
onelionhunter's Avatar
onelionhunter
IIRC
IIRC the gray CPS is known to cause some strange idle issues at times.
Old Apr 20, 2010 | 11:06 AM
clintbonnie's Avatar
clintbonnie
You might also check your ICP sensor for a oil leak. Also you can unplug it and see if the miss stops..
Old Apr 20, 2010 | 11:10 AM
TN97STROKE's Avatar
TN97STROKE
Thanks, I will all these things
