My biggest questions is my speed sensor. I pulled the codes off of my truck and it was telling me I had a bad sensor basically the circuit failed on the rear pumpkin. Ok it wasn't expensive so I went to replace it. Well that did not work I'm still getting the flashing ABS light and my speedometer still goes crazy. Is it possible that the sensor Ford gave me is bad too or what?
My next question is this past winter I could swore I had a Anti slip diff or possi I call it a possi. But when I power brake it to mess around with ricers its one wheel wonder. Could it be that me clutches in the rear are bad.
My truck is an 04 f-350 CC Long bed PSD
The second question is an easy one. The Ford limited slip is very weak, and even when new is not strong enough to prevent a one wheel burnout. And doing one wheel burnouts is a sure way to ruin it completely.
It is always possible to get a bad sensor out of the box. But I can't help much on other possible reasons for the failure. Maybe an ABS wheel sensor?
Did you check the wiring loom for damage?
Crap gets tossed up there all the time.
