Rear Spring Isolator???
Old Apr 20, 2010 | 06:58 AM
ez4u2chere's Avatar
ez4u2chere
I'm about to switch from LLS to Coil Springs on the rear of my '98 2x4.
I'm probably going to go with OEM or MOOG springs.
I keep reading some posts on here that mention replacing/adding Spring Isolators.
Is this something I need to purchase as well? Or are they already on the truck?
I notice most of the aftermarket kits do not mention anything about their kit containing spring isolators. In fact, the strutmasters video on youtube doesn't mention it or show it.
So.... Do I need to purchase these? Or should I be good to go? I don't want to be half way through the job to find out I need another part.
Old Apr 21, 2010 | 11:39 AM
ez4u2chere's Avatar
ez4u2chere
So I guess I don't need to worry about the isolators
Old Apr 21, 2010 | 02:45 PM
Moto Mel's Avatar
Moto Mel
I'm not certain but I believe the "spring isolators" are the rubber insulators placed on the ends of the springs from the factory. Sometimes they are in the form of a fitted pad and sometimes they look like pieces of slotted rubber hose that goes on the ends of the coils. The aftermarket spring suppliers usually only provide a square of rubber gasket material in place of the OEM isolators/insulators.
You will need the Isolators or you will have a lot of noise from the springs rubbing on the mounts.l
Old Apr 21, 2010 | 07:27 PM
ez4u2chere's Avatar
ez4u2chere
Thanks Moto Mel. That's kind of what I was speculating myself. What I find odd is that most of the aftermarket kits do not come with them, there is nothing in the instructions about them that come with the aftermarket kits, and event StrutMasters own YouTube video doesn't mention them.
I didn't know if it was something already built in above/below the existing airbags.
6:15~ of StrutMasters VIDEO.
Old Apr 21, 2010 | 10:04 PM
Moto Mel's Avatar
Moto Mel
6:15~ of THERE VIDEO.
Based on their video I have to say that Isolators/Insulators are not needed, I'll check my service manual in a few minutes and let you know. My experience with coil conversions are based on my experiences with Mark VIIIs.
Old Apr 22, 2010 | 01:01 PM
Moto Mel's Avatar
Moto Mel
In checking my manual I can find no mention of Isolators on the rear springs, I hope this helps.
Old Apr 22, 2010 | 04:08 PM
ez4u2chere's Avatar
ez4u2chere
Thanks. Looks like this will be an easy job then. I appreciate you looking that up for me.
Old Apr 22, 2010 | 07:57 PM
Moto Mel's Avatar
Moto Mel
You're welcome. I hope it works out well for you.
Improv101
Dec 1, 2024 10:06 PM
Brown Falcon
Nov 13, 2016 09:01 PM
BruteFord
Electrical Systems/Wiring
May 11, 2016 02:33 PM
caspermj
29
Feb 16, 2015 07:08 PM
beratte
39
Feb 15, 2015 03:01 AM
