rear diff
Old Jan 28, 2003 | 11:46 PM
bradc's Avatar
bradc
rear diff
hi. does anyone know if the rear end from a 66 f100 would go into a 64 f350?
Old Jan 29, 2003 | 05:15 AM
jowilker's Avatar
jowilker
rear diff
Not as a swap in. the 1/2 ton uses the Ford 9", and the 1 ton uses a Dana. You can swap the complete axle housing under the 350 but it isn't nearly as strong as the Dana.
Old Jan 29, 2003 | 02:14 PM
Rosati's Avatar
Rosati
rear diff
You can swap the entire axle like John said but I would also suggest getting the springs and spring mounts off the frame. You'd be basiclly converting to a 1/2 ton. I beleive there is little difference in the frames.
copeina
1997 - 2003 F150
Sep 18, 2002 03:14 PM
bjoern
Sep 3, 2001 09:07 PM
jowilker
Mar 3, 2000 07:19 AM
Nik
Jan 3, 2000 10:47 PM
