help need a write up on swaping intakes
Old Apr 19, 2010 | 07:51 AM
YoungMT Hick's Avatar
YoungMT Hick
looking for a how to on swapping intakes i have a 390 4brl intake going on a 360 and i would like help see how to change the intake thanks
Old Apr 19, 2010 | 12:31 PM
Bear 45/70's Avatar
Bear 45/70
Unbolt the old manifold and scrap the gasket surfaces and the using new gaskets set the new intake on and bolt it down. This ain't rocket science here, this is a direct bolt on. Of course you need either a 2 to 4 barrel adapter of a 4 barrel carb, but that ain't all that hard either.
Old Apr 19, 2010 | 08:18 PM
YoungMT Hick
ok nvm i was talking about having to take off the rocker arm assembly thanks though
Old Apr 19, 2010 | 10:48 PM
Bear 45/70's Avatar
Bear 45/70
All you do is unbolt the rocker arm shaft keeping the bolts in their appropriate stands, remove the push rods, keeping them in order and the reinstall them. Oh and You shouldn' be doing anything to your motor without a manual for reference.
