IVE HAD THE TRUCK FOR 4 MONTHS NOW AND IT SEEMS TO WANT TO PULL LEFT ONE DAY THEN RIGHT THE NEXT AND SOME DAYS ITS FINE NO EXSESIVE TIRE WEAR OR ANYTHING LIKE THAT DO SERTTAIN TIRES LIKE TO FOLLOW THE ROAD ??
Im not too sure but ive noticed some roads i can let off the wheel and go for miles straight and others it will pull i believe some roads are not actually flat they have a high point in the middle so maybe the truck is just going with the lean in the road. I dont know but thats just my 0.02 cents
My truck does the same. I need to change my track bar bushings and I need an alignment, but if the track bar isn't centered due to wallowed out bushings I can see how it possibly could cause what you describe...
joe you are right, not all roads are flat..at least where i live. some have a high point mostly for flood prevention so that may be the issue in question. i could be wrong but its my .02
wasn't there an issue with steering wander on the PSD's??...i can't remember...if so, wouldn't correcting that fix this issue too???....there's my .02...lol
