Transmission Problems
Old Apr 16, 2010 | 05:38 PM
1998f150stx's Avatar
1998f150stx
Unhappy Transmission Problems
97 F150 4x4 transmission is grinding in first gear then gets a little quieter as the speed is increasd but if i put the trans in reverse to back up it locks up but breaks loose when you give it gas or play with the 4x4 switch on the dash i checked everything like the transfer case motor, hub solenoids, everything looks like its working fine there if someone might be able to tell me what they think is wrong thanks
