Dana 44 Spline Count... ??
Old 01-28-2003, 06:04 PM
jberylecrider's Avatar
jberylecrider
jberylecrider is offline
Hey all!
Does anyone know if the splines are the same from a 1979 Dana 44 solid axle to a 1994 Dana 44 TTB axle ?
I am trying to re-use the '94 drivers side axle shaft for rebuilding a '79 axle.
I know the passenger side wont work because of the extra TTB joint. But hoping that some of this stuff will convert over.
What about the carrier, bearings, ring & pinion?
Is anything the same? If not, then why is the TTB even called a Dana 44? Why didn't they just give it a different name?
Thanks!
Old 01-28-2003, 07:30 PM
honney's Avatar
honney
honney is offline
Spline counts are the same, and I'm sure spline pitch is also the same, but the length is gonna be way different. IIRC even the stubs are different lengths, but I could be wrong.
They call it a D44 because all of the following are the same:
1.spline count
2.axle shaft dia
3.carriers
4.carrier bearings
5.ring and pinion
6.pinion bearings
7.lockouts
8.wheel bearings
9.ujoints
10.yokes
11.pinion nuts
to name a few
Old 01-29-2003, 01:00 AM
jberylecrider
Thank you so much for the info!!
The most important parts I need to know about are:
Spindle, caliper support, rotor, & hub
Are all of these '94 parts compatible with the '79 axle?
If my thinking is correct...
The bolt pattern off the knuckle is the same on both axles then the spindle and everything out from it on the 1994 axle can be installed on the 1979 axle, right?
Then I can use all of the 'knuckle-out' parts off of my 1994 axle to rebuild my 1979 axle, right?
It all boils down to the knuckle/spindle bolt pattern and splines, if they match up then I am set.
Anyone know for sure?
Thank you !!
Old 01-29-2003, 09:18 AM
honney's Avatar
honney
honney is offline
I'm 99% sure none of that will work. The 78/9 spindles are 5 bolt while the TTB is 6 bolt. And you can't put the 78/9 knuckles on the TTB arms because the ball joint spacing is different.
Old 01-29-2003, 01:20 PM
jberylecrider
That sucks!
Well atleast I can use the hub assembly & locks, right?
Thanks!
Old 02-03-2003, 01:09 AM
85351ho's Avatar
85351ho
85351ho is offline
right
KingProvince
05-20-2017 11:47 PM
justcruzin125
11-09-2016 10:48 AM
BlueOvalBud
77
05-02-2012 06:23 PM
rancherman84
01-06-2004 09:27 PM
sharker98
11-12-2003 12:03 PM
Quick Reply: Dana 44 Spline Count... ??
