Sponsored by: Real Truck
__NO__ Power__ to the Key Switch___
Old Apr 16, 2010 | 12:39 PM
eldorado's Avatar
eldorado
Electrical supply problem, maybe someone can tell me if and where a fuse or breaker might be that controls the "key switch"
PROBLEM: no power, nothing happens when turned to ON or START, shift level will not move, BATTERY is FINE, plenty of juice!!!!
Checked both fuse panel and cannot find any broken.....?
Maybe there is a seperate fuse/breaker somewhere under the dash ?
Also...NO lights or gauges are functioning since the switch is not turning on.....horn, headlights, tailights, interior dome all work fine.
Old Apr 16, 2010 | 01:23 PM
gearloose1's Avatar
gearloose1
Get a VOM and see if there is power going to the key switch.
If there is not.. start to work backwards.
Also, while you are at it.. do a reset as per link below.
Nuttycollector
All Other Items for Sale
Sep 29, 2012 08:52 PM
Nuttycollector
Sep 16, 2012 08:26 AM
DRRXR
31
Mar 23, 2010 10:16 PM
mitey SnoBird
Jan 4, 2010 11:19 AM
thinglenn40
Jul 8, 2007 05:15 PM
