Sponsored by: Real Truck
Cannot remove auto locking hub
Old Jun 2, 2014 | 09:16 PM
  #31
99f350sd's Avatar
99f350sd
I even have pics LOL...I drilled it a bunch and with a chisel broke it..Used slide hammer to get pieces out. What happens is white corroded aluminum and rust possibly.
Old Jun 2, 2014 | 09:27 PM
  #32
99f350sd's Avatar
99f350sd
Old Jun 3, 2014 | 03:40 AM
  #33
PASandman99's Avatar
PASandman99
Good Lord! I was hoping to avoid doing that but after a can of PB Blaster it seems as stuck as ever. I was thinking about trying to use a slide hammer attached to a vice grip. I'm probably just delaying the inevitable. Something tells me that a drill and chisel are in my future. Thanks to everyone for the replies.
Old Jun 3, 2014 | 06:14 AM
  #34
tilelayher's Avatar
tilelayher
PaSandman we are in the same boat, chisel party!!
I am thinking of replacing the bearing hub assemblies and ball joints while I am in there, I plow with this truck and it needs a major overhaul
Old Jun 3, 2014 | 02:40 PM
  #35
tilelayher's Avatar
tilelayher
I drilled this afternoon took me 2 hours i got the hub out, it was frozen in there good. Now the drivers side, i can get to wiggle but I still cant get it out. I bought some huge pliers that fit around it.
My passengers side Bearing assembly is shot, who makes a decent but afordable one for use with snow plowing.
Old Jun 3, 2014 | 06:21 PM
  #36
99f350sd's Avatar
99f350sd
Wow good work..
Dick
Old Jun 3, 2014 | 07:05 PM
  #37
tilelayher's Avatar
tilelayher
The trick was the slide pull, I do not know my approach on the next one since it is wiggling but it refuses to come out.
Old Jun 4, 2014 | 07:01 AM
  #38
PASandman99
That's great news tilelayher! What do you mean by a slide pull? Slide hammer?
Old Jun 4, 2014 | 10:19 AM
  #39
tilelayher's Avatar
tilelayher
Yes I used a slide hammer i drilled some 5/16 holes all over to weaken it, cracked it into smaller pieces then drilled 1/8" hole and threaded a screw into it and pulled it, once you get a piece or 2 out the larger chunk comes out in the same manner, i did the drivers side this morning took me a half hour, still needed to drill and crack it but you casn see for the most part it came out in 1 piece. Its not as bad of a job as you think.
Kemicalburns
Dec 19, 2016 02:20 PM
Amaford
Jul 4, 2016 01:40 AM
billionj
Nov 21, 2015 09:53 PM
cattlerancher
Nov 27, 2014 08:43 PM
tdwarburton
May 31, 2014 11:14 AM
