Engine Serial Number
Old Apr 15, 2010 | 10:23 PM
redman84's Avatar
redman84
Where can I find the serial number on my 96 7.3?
Old Apr 15, 2010 | 10:26 PM
foxracing0934's Avatar
foxracing0934
I'm pretty sure that the s/n for the 7.3 can be found on the sticker on the passenger valve cover. If that sticker isn't there anymore then it is stamped in the block somewhere but I don't remember where it is.
Old Apr 15, 2010 | 11:51 PM
oldbird1965's Avatar
oldbird1965
Man, I can't remember eighter. I got mine a few years back, its on a flat smooth part of the motor above the oil pan somewhere, isn't it?
Old Apr 16, 2010 | 10:58 AM
250turbo's Avatar
250turbo
stamped on block by oil filter.
Old Apr 16, 2010 | 11:16 AM
Neal 97 250's Avatar
Neal 97 250
It is sometimes stuck on the HPO reservoir. But the physical stamp is near the oil filter. I think it is written vertically. It is to the rear of the oil cooler above the filter.
Old Apr 16, 2010 | 12:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
here you can find it (two first pics and maybe in the third)
Old Apr 16, 2010 | 01:01 PM
redman84's Avatar
redman84
Thanks a ton! Found it
Old Apr 16, 2010 | 02:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
You are welcome, glad to help you.
Old Mar 13, 2023 | 05:48 PM
Tader88's Avatar
Tader88
1st Gear
4JU2U20096c is my engine serial number I need to know what timing cover to order can anyone help?
Old Mar 14, 2023 | 03:12 PM
knottyrope's Avatar
knottyrope
https://www.enginelabs.com/engine-te...ers-1952-1996/
think you are missing a letter
Old Dec 8, 2024 | 11:09 AM
diggit22's Avatar
diggit22
Trailering
Any help with my engine serial would help. Pretty sure this is a remanned or rebuilt motor based on what I’ve read.7.4JU2U1921160
Im replacing my radiator and oil cooler in my 02 excursion but I’m not sure what coolant type to use, conventional with sca or hd elc. I have upgraded the injector cups to stainless if that makes a difference of what I should use. Any help would be appreciated. Thanks in advance.
Old Dec 8, 2024 | 08:33 PM
z31freakify's Avatar
z31freakify
If the stainless cups you used were from Riffraff I'm sure they give out the correct sealant to use ELC. Some members here have used ELC with 94.5-E99 factory sealant with no leaks, so there's that.
Old Dec 10, 2024 | 10:21 AM
diggit22's Avatar
diggit22
Trailering
z31freakify you hit the nail on the head. I used Loctite 620 compound from riff raff.
thanks
444dieselrod
Mar 8, 2016 08:49 AM
bigcrunch
Large Truck
Aug 16, 2015 08:16 AM
matts_auto
Jun 12, 2014 11:21 PM
Myfreeford
Nov 19, 2010 10:33 AM
1997stroker
Jun 26, 2007 05:38 AM
