Sponsored by: Auxito
knock knock
Old Apr 15, 2010 | 09:12 PM
mad mech's Avatar
mad mech
knock knock
97 f-150 has a knock at the bell housing. Scoped the block,the heads, everywhere. The loudest point seems to be coming from around the starter,any have any idea what it might be?
Old Apr 16, 2010 | 07:01 AM
Joe Finn's Avatar
Joe Finn
Maybe a cracked flexplate
Old Apr 17, 2010 | 01:00 PM
RobbyMartin's Avatar
RobbyMartin
What needs to be done to replace a broken flex plate?
Old Apr 17, 2010 | 05:36 PM
fordmerc's Avatar
fordmerc
The transmission has to come out then it just unbolts from the crankshaft. I would first pull the starter and spin the flex plate with a large screwdriver or something similiar and see if you can see any damage.
Old Apr 17, 2010 | 07:43 PM
RobbyMartin
My truck has the same noise and I did check for cracks and loose bolts and there wasn't anything obvious. Would it be an obvious crack?
Old Apr 17, 2010 | 09:30 PM
fordtech08's Avatar
fordtech08
if it is cracked it's right by the crank and you wouldn't be able to see it
