cam phaser labor
Old 04-15-2010, 05:55 PM
1bad67sbf's Avatar
1bad67sbf
1bad67sbf is offline
cam phaser labor
i want to know how many hours a dealer calls for to install cam phasers and would they care if i supply parts to install (i can get them cheaper online)
Old 04-16-2010, 07:58 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Straight book time is 7.7 hrs. I doubt they will warranty the work if you supply the parts.
Old 04-16-2010, 08:09 PM
1bad67sbf's Avatar
1bad67sbf
what if the parts are from ford just not that dealer? whats the ball park $ per hour, like $85 per hr?
Old 04-16-2010, 08:31 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
I doubt you will find a shop that will do the job at a reasonable rate with you supplying your own parts unless you have a friend with a shop.
The link below is a DIY (how to) write up, just DIY.
http://www.f150online.com/forums/art...placement.html
Old 04-16-2010, 08:48 PM
1bad67sbf's Avatar
1bad67sbf
i know i looked around at the job but if it was my toy truck i would be doing that but its my every day ride and if something turns for the bad i cant go with out it for long. i almost changed the plugs myself and i did not, then 4 of the 8 broke off but it was at a shop that had the tools for the job and time to fix it for me. i dont have a car port or anything what i do i do outside. i hate it, im getting a tent style carport soon (but for the mustang)
Old 04-17-2010, 07:19 PM
Greg B's Avatar
Greg B
Greg B is offline
Most dealerships in my area charge over $120 per hour. An independent shop charges $60-$80 per hour for labor.
Old 04-17-2010, 08:50 PM
1bad67sbf's Avatar
1bad67sbf
when changing them you have to use a wedge to keep the timing chain set, if it slips it is due to the person with the tool in hand. my ? is if they dont do that step right they have to tear down the front of the motor to retime it, would a shop charge more if they do something wrong and add a couple of hours to the bill (dealer vs local shop)
Old 04-17-2010, 09:28 PM
sparky357's Avatar
sparky357
sparky357 is offline
1b67 can you tell me what kind of symptoms or indicators you had that would require the cam phaser to be replaced????
Old 04-17-2010, 09:33 PM
1bad67sbf's Avatar
1bad67sbf
the normal rattling on startups and rattling from 800-1200 rpms. they have a little rattle at idle but not that bad yet
Old 04-17-2010, 09:34 PM
Greg B's Avatar
Greg B
Greg B is offline
A reputable shop or dealer that is honest and operates with integrity wouldn't charge you more if they made a mistake. They would just eat the additional cost. But a shop that operates that way is getting harder and harder to find these days. There are a few in my area of northern Indiana, but very few. Those are the ones I do business with and recommend to others. You'll just need to ask around in your area if there are shops that do business that way.
Old 04-18-2010, 10:28 AM
tseekins's Avatar
tseekins
tseekins is online now
Received 1,234 Likes on 810 Posts
Good point and you cant fiddle around with these guys either. Ask them very politely if they cover their mistakes in the price that was quoted. Make no assumptions, everyone is hungry these days.
Old 04-18-2010, 03:33 PM
1bad67sbf's Avatar
1bad67sbf
yeah i think using a local shop that is fair is the way to go. thier is a shop near my work that has good people working thier and one is a ford tech from a dealer. they also are a small race shop on the side
Old 04-18-2010, 11:33 PM
Peter94's Avatar
Peter94
Peter94 is offline
Where did you find the Phasers online? How much? I want to buy, local dealer wants 190 per side for the phasers I believe.
Old 04-19-2010, 04:23 PM
1bad67sbf's Avatar
1bad67sbf
Ford Parts - Silver State Ford Parts $170 per side. i think thes was the part number but double check 3R2Z-6A257-DA
Old 04-19-2010, 11:29 PM
Peter94's Avatar
Peter94
Peter94 is offline
Geeze those things are expensive! 340 for both sides. I should save up and do mine. Just take it like a man I guess. Oh well my noisy ones should make it to MI and back a few times i think.
Quick Reply: cam phaser labor
