Bolt pattern NEED HELP!!
Old Apr 15, 2010 | 03:27 PM
Loud4.9's Avatar
Loud4.9
Ordering rims for my 1980 f150 2wd with the twin eye beam front end out of a 86 f150 2wd ive read my bolt pattern would be 5-5.5'' (or 5-127mm) anybody no if this is correct?? thanks
Old Apr 15, 2010 | 04:51 PM
Franklin2's Avatar
Franklin2
If your truck has the stock 86 f150 front, yes it will be 5 on 5 1/2 bolt pattern.
Old Apr 15, 2010 | 10:19 PM
Loud4.9's Avatar
Loud4.9
Okay thanks alot man!
Old Apr 16, 2010 | 09:26 AM
f100jim's Avatar
f100jim
For what it's worth, 5.5" is 139.7mm, not 127mm. Wouldn't want you to order wheel what won't fit.
Old Apr 16, 2010 | 09:30 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by f100jim
Short bed pickups are like ***** on your ex-wife: if they are dressed up they may LOOK nice, but that's all they are good for!
Bestest sig ever!
+ rep for it.
Old Apr 18, 2010 | 09:00 PM
Loud4.9's Avatar
Loud4.9
I double cheaked 139.7mm is the one thanks!
Old May 5, 2010 | 04:49 PM
TSHuckeba1's Avatar
TSHuckeba1
How to determine bolt pattern
Measure from the two furthest studs. If you have 5 studs, and you number them, you would measure from stud 1 to stud 3.
4, 6, and 8 lug. Measurement is the distance from opposite studes. On an 8 lug, it is number 1 and 5 measures straight acroos the center.
Hope this helps.
Jake616
Jul 6, 2010 01:13 PM
kye
1997 - 2003 F150
Mar 26, 2008 05:42 AM
slow_v6_stang
Feb 1, 2006 07:40 PM
OzarksFord
Nov 4, 2005 10:55 PM
mnstang
May 30, 2004 10:01 AM
