Need help wiring an indash clock!
Old Apr 15, 2010 | 02:08 PM
Tomdoc's Avatar
Tomdoc
Need help with the wiring of an after market clock that I just installed in my 05' Excursion 6.0 Power Stroke. I mounted the 2 1/8" clock next to the power point on the dash ( it fits there perfectly!). The hot lead to the clock I wired into the power point fuse in the fuse box (costant 12 volt source). I can't seem to locate where to wire the hot lead for the clocks light. It needs to be wired into the dash lights so the clock light comes on with the dash lights and so it can be on the same circut as the dash lights dimmer. Can this be done in the fuse box???
Thanks, Tom.
Old Apr 15, 2010 | 03:43 PM
BostonX73's Avatar
BostonX73
if you pull the light switch you should be able to find the wire that comes on with the parking lights
CountryBumkin
23
Jun 22, 2014 10:05 PM
Brad_81Ford
'80-'86 FAQs (Frequently Asked Questions)
80
Nov 28, 2013 06:51 PM
chasecbc
2009 - 2014 F150
Jul 8, 2013 10:04 PM
brthevio
Apr 20, 2008 11:17 AM
cujo8
Mar 8, 2008 09:06 PM
