Tranny match up
Old Jan 28, 2003 | 02:13 PM
Ford_a_holic's Avatar
Ford_a_holic
Tranny match up
Will the Mazda 5 speed Tranny match up to the 351w and will it be able to handle the power of the 351?
Old Jan 28, 2003 | 03:14 PM
HotWhlz85's Avatar
HotWhlz85
Tranny match up
I'm pretty sure it will. Ford used this tranny a lot in the mid to late 80's mated to a 300 six. The 300 and 351W use the same bellhousing. I would imagine that Ford built some trucks with the 351 and this 5 spd, but can't say that for sure. I'd also imagine that it can handle the power output from the 351. The only negative I have heard is that the Mazda is not a very durable one.
Ron
Old Jan 28, 2003 | 08:23 PM
BlueOvalRage's Avatar
BlueOvalRage
Tranny match up
I agree. Yes and no. Assuming that you use the correct 351W flywheel, it will bolt up like it belonged there. No, this gutless wimp will not take the torque of a 351W. Even a stock motor will twist it apart if you push it very hard. And you will. Why else would you want to go to a bigger motor?
64custom
Feb 26, 2014 09:45 PM
t bird 2.0
Mar 11, 2011 11:08 PM
nike9623
Jul 6, 2009 06:14 PM
Stollers83F100
13
Jul 21, 2008 05:24 PM
jenkinsj
Jan 16, 2008 05:30 PM
