transfer case
Old Apr 14, 2010 | 04:09 PM
limptera13's Avatar
limptera13
transfer case
so it looks like the seal is bad where the trans meets the transfer case, 4 spd manual with a 302 on my 86 fyi....before i get into it i want to see whats ahead of me before i start, looks failry easy just some work involved
Old Apr 15, 2010 | 04:25 AM
limptera13's Avatar
limptera13
Any one??????
Old Apr 15, 2010 | 07:54 AM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Seal or gasket. Where is it leaking? My T-19 had a paper gasket between the two. I suppose if that's your problem then you would just remove the drive shafts, drop the T-case and replace it. The T-case is one of the easier "big" things to remove.
Old Apr 15, 2010 | 08:25 AM
limptera13's Avatar
limptera13
Looks like the very bottom where they meet. It looks pretty simple
Old Apr 15, 2010 | 08:42 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Is the liquid coming out reddish or dark? If it's red in color, it's ATF from the TC, if dark, it's gear oil from the trans.
If it's just the gasket between the trans and TC, then you just need to drop the TC and clean both surfaces, then either use a gasket or silicone to seal it up.
While you have the TC out, you might check the trans rear seal, and TC front seal (if equipped), as it's the perfect time to replace if they look like they need it.
