CCV Mod
Old Apr 14, 2010 | 03:11 PM
RobertJohn's Avatar
RobertJohn
Question CCV Mod
OK, the drivers side has a CCV, why doesn't the pass. side ? Are the valve covers interchangeable ? If so I could just use a drivers side on the pass. side, do the mod, then have both sides done.
Old Apr 14, 2010 | 03:45 PM
clintbonnie's Avatar
clintbonnie
There is really no need to do both sides.. the entire inside of the engine breathes thru the driver's side just fine..
Old Apr 14, 2010 | 03:46 PM
Quick444's Avatar
Quick444
I would assume because the CCV on the one valve cover is taking care of pressure build up for both sides.
Old Apr 14, 2010 | 04:20 PM
clem1226's Avatar
clem1226
it's called CCV because it is Crank Case Ventilation, there is only one Crank case so your good to go.
Now if it was VCV........................
Old Apr 14, 2010 | 04:24 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Where would you put the oil in the engine if you could use 2 drivers side VC? They are different.
Old Apr 14, 2010 | 06:16 PM
1999SuperD's Avatar
1999SuperD
Clem1226 has a very good point that its Crank Case Ventilation and not Valve cover Ventilation
Old Apr 14, 2010 | 07:21 PM
serviceguy's Avatar
serviceguy
The pressure that builds in the crank case can be exhausted through ether side as any pressure built is equalized through the oil return galleys that return oil from the valve train and injectors back to the oil pan. So it is only necessary to open one side to atmosphere as they are tied together.
Old Apr 14, 2010 | 08:21 PM
guzzle92's Avatar
guzzle92
The only reason that I could think of to vent both sides would be to reduce any possible backpressure that a longer hose run to the back of the truck could potientially cause. Two runs would give you twice the area of vent and 1/2 of the restriction.
Not a bad idea RobertJohn but I don't believe that the valve covers are swappable ....
Old Apr 14, 2010 | 08:54 PM
PaysonPSD's Avatar
PaysonPSD
Brandon (bdrummonds) ran a passenger side CCV through the top of the oil fill cap.
Don't you guys remember that?
I have a spare set of VCs and have thought about mounting a dog house on the passenger side VC. I just don't have a spare dog house. Don't really know if there is even room to do it.
