abs speedo problem
Old Apr 14, 2010 | 11:00 AM
njtinman2's Avatar
njtinman2
abs speedo problem
ok i have a 94 f150 4x4 and the abs and brake lites are on i replaced the speed sensor in the diff and have not found 1 in the trans or transfer case. now this all started before changing the sensor the speedo jumps all over the place also and when the truck drives about 10 to 20 miles when i come to a stop the oil press gage drops and bounces all over the place so im looking for ideas and yes the pressure sensor has been changed
Old Apr 14, 2010 | 11:09 AM
Bob Gervais's Avatar
Bob Gervais
You have a few separate issues going on.
Speedo/ABS: Could be a bad ABS module, which is behind the glove box. Pop the glove box out, the black box that's right behind it is the ABS module. Unplug it, test drive and see what happens. If that's not it, it could be the tone ring in the rear diff, or a bad PSOM (speedometer). Make sure all the wiring from the rear sensor is good as well.
ABS/brake light can also be caused by low fluid level in the master cylinder.
Oil pressure gauge: Could be an indication of internal wear (rod/mains), a bad oil pump or clogged pickup screen. Put a known good mechanical pressure gauge on it to find out for sure if it's low oil pressure.
Old Apr 14, 2010 | 11:52 AM
njtinman2's Avatar
njtinman2
oil press is good just the gage in the dash was tring to find out if the gage problem is common to each other
Old Apr 14, 2010 | 12:31 PM
SlowNSteady's Avatar
SlowNSteady
ground maybe? just the first thing that came to mind.
Old Apr 14, 2010 | 02:02 PM
njtinman2's Avatar
njtinman2
im thinking ground also but under the hood is all good
Old Apr 14, 2010 | 02:06 PM
ymeski56's Avatar
ymeski56
Der Postmeister
X2. or the float gets stuck in the m/s.
Old Apr 14, 2010 | 02:08 PM
ymeski56's Avatar
ymeski56
Der Postmeister
More likely the sender unit.
Old Apr 14, 2010 | 02:14 PM
njtinman2's Avatar
njtinman2
i know its got to do with wire og ground because i grounded the wire after the engine was hot and the gauge still played games
Old Apr 14, 2010 | 02:33 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Ya, it should stay pegged over while grounded, unless the wire is compromised somewhere on it's way to the gauge. Can someone watch the gauge while you wiggle the wire while well grounded?
Old Apr 17, 2010 | 02:00 PM
njtinman2's Avatar
njtinman2
im starting to think it is something common to the dash cluster
