Sponsored by: Real Truck
trouble with power driver side window
Old Apr 13, 2010 | 11:42 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
The driver side window will slow down when it gets about half way down or sometimes stop and not go the rest of the way down. Anyone else had this problem and what was the cause? Thanks.
Old Apr 13, 2010 | 11:48 AM
Fishin76's Avatar
Fishin76
Mine seems to work intermittently right now, Can't figure out if it is the switch, or the motor, when it works, it works well.
Old Apr 13, 2010 | 11:50 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
mine acts like it is binding or something is dry. Maybe something out of adjustment.
Old Apr 13, 2010 | 06:18 PM
Franko72's Avatar
Franko72
Molon Labe
I've heard of people using a clear silicon spray on the felt tracks with success. I haven't tried myself yet, but I do have a slugish one also.
Old Apr 13, 2010 | 08:18 PM
Monster-4's Avatar
Monster-4
Heavily spray the window track with silicon spray and run the window up and down several times. It will make a big difference.
Old Apr 13, 2010 | 09:18 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
When you say window tracks do you mean the ones inside the door or the felt along the top of the door?
Old Apr 13, 2010 | 09:23 PM
Franko72's Avatar
Franko72
Molon Labe
I think Mike meant the horizontal tracks, I was refering to the felt verticle ones.
Hell, spray everything LOL. It cant hurt
Old Apr 14, 2010 | 05:06 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Any tips or tricks to pulling the door panel off without breaking anything? Thanks.
Old Apr 14, 2010 | 06:42 AM
Monster-4's Avatar
Monster-4
Actually I was referring to the vertical felt tracks. You don't need to pull the door panel off. With the window up take the straw that came with the silicon spray and stick it as for down as you can along the bottom of the window inside the vertical track. Give each side at least a 10 second spray. Then put the window down as far as it will go and then spray the vertical track above the window. Put the window back up. Spray again at the bottom of the window with the spray straw inside the track. Put the window back down as far as you can and spray the vertical track above the window.
Repeat until you can put the window all the way down. It will take a few cycles but if it's just the tracks being dry this process will eventually work and allow the window to roll all the way down. Just remember to re-lube the tracks every time you change the engine oil or at least a couple times a year.
Old Apr 14, 2010 | 07:42 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Very good, simple enough to try. Thanks guys.
Old Apr 14, 2010 | 09:03 AM
rickf92592's Avatar
rickf92592
On the 05 the door panel was super easy to get off. Mine needed lubed on the roller and pivot points on the mechanism that lifts the window. No way to get at those without removing the panel. Took me about 20 minutes for the whole job. (The manual helped.)
Old Apr 14, 2010 | 09:17 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
"the manual" is like one of the hayes or chilton ones?
Old Apr 14, 2010 | 09:20 AM
rickf92592's Avatar
rickf92592
Haynes, has the whole process for removal.
BTW, used motorcycle chain lube; goes on wet and 'dries' to waxy.
