Sponsored by: Real Truck
'06 KR Arm Rest switch
Old Apr 13, 2010 | 09:48 AM
Lonewolftx's Avatar
Lonewolftx
Question '06 KR Arm Rest switch
I would like to switch my arm rests from Passenger side to driver chair to "flip over" the arm rest due to wear on drivers but none on passengers. Anyone know how to remove these arm rest from the KR Captain chairs?
Old Apr 13, 2010 | 09:50 AM
Maxium4x4's Avatar
Maxium4x4
I bumped you to SuperDuty, the guys will have a better answer to your question here.
Old Apr 13, 2010 | 10:34 AM
scottzj's Avatar
scottzj
Hangin 10 bra
There's a torx head bolt at the swivel point, I believe its a T-50. If you stick your finger between the seat and the armrest, you should feel the hole in the leather where the bolt goes through. It's strethed over the armrest so you can push it up towards the end to expose the bolt, or peal the material back.
Now as far as swapping them, I am not sure about that part.
Old Apr 13, 2010 | 10:55 AM
Lonewolftx's Avatar
Lonewolftx
Thumbs up Thanks . . .
So the bolt is on the post between the arm rest and the seat? Or on the arm rest itself? Or the seat itself? I will look at lt later to try and find it. I would guess if they both come off they should trade out from driver to passenger seat . . .
Old Apr 13, 2010 | 11:36 AM
scottzj's Avatar
scottzj
Hangin 10 bra
The bolt is in the armrest that connects to the side of the chair. You will need to peal back some of the leather at the end of the armrest and feel around for the hole. Then get your torx bit and loosen the bolt to remove it. Just be carefull when pulling the leather around the foam, as you could tear it or mark it.
Old Apr 13, 2010 | 12:20 PM
Lonewolftx's Avatar
Lonewolftx
Thumbs up All Done . . .
Got it. Really didn't need to take the arm off after all as all I wanted to do was switch the covers so the worn drivers side was down on the passengers and vice versa.
Didn't realise it was so easy to get the covers off. Thanks for help and insight!
beachcomer1962
Aug 30, 2013 01:00 PM
spongecop
Jan 23, 2012 07:53 PM
Tricialy
Aug 5, 2003 09:45 PM
