Help please with an Axle Question
Old Apr 13, 2010 | 03:09 AM
mdwirth's Avatar
mdwirth
Having tried a search with no result's unless I did it wrong...I would like to keep the 9" rear in my 65 f100, I would like to change from the truck bolt pattern to the car bolt pattern, I have the front covered, I do not want to use adapters as I had a bad experience with those years ago. I know I could just have the flanges redrilled but prefer not to, I am looking for a take the old axles and drums out and slid in axles and drums from a -------- and away you go, please can some one fill in the blank space. It seems I have heard of something before but cant find it now. Thanks!!!
Old Apr 13, 2010 | 03:43 AM
jowilker's Avatar
jowilker
Bill probably will be most helpful here, several of the large cars used the 9" back then. Thing is length and he can provide those. I believe you can play with a little difference in length without it being an issue.
I know there is a difference in the axles that I run from a 68-72 in my 66 with the larger rear brakes.
John
Old Apr 13, 2010 | 05:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No 9" passenger car axleshaft will exchange with a F100 axleshaft.
The lengths are different and most passenger cars have right/left specific axleshafts.
Some passenger car axleshafts use the small ball bearing, some use the large ball bearing, some (1974/79's) use a tapered roller bearing/seal combo.
Thru 1979: Some passenger cars have a 4.50" bolt pattern, some have a 5.00" bolt pattern.
No 9" in passenger cars after 1979.
