Fuse box.
Old Apr 12, 2010 | 07:04 PM
jimford1's Avatar
jimford1
Fuse box.
Hey guys my 68 ranger has the old a$$ round fuse fuse box. It seems like all the wires were just spliced and slid in behind the fuse. half a$$ed. What should I do?? Is there a fuse box I could use that would work, maybe off an f 150 from he junkyard or something? Thanks !!
Old Apr 12, 2010 | 09:46 PM
Franklin2's Avatar
Franklin2
They have small auxilary fuse boxes you can buy in the parts stores. They take the modern type fuses. They are usually hanging on the rack with the fuses, relays, and flashers.
Old Apr 13, 2010 | 02:37 PM
gearloose1's Avatar
gearloose1
Hate to say this...
The old box is working fine.
The round fuses are dirt cheap.
Have you check the prices for mini-blade fuses?
Why bother changing anything when it works?
Old Apr 16, 2010 | 11:23 PM
TC-Countryboy's Avatar
TC-Countryboy
If you are needing extra circuits there are a lot of auxilary fuse blocks available with various number of circuits.
Here are some options, you could mount on the firewall under the dash. Just run a wire heavy enough to handle the combined load from the battery to the block with a circuit breaker on the battery end.
ATO/ATC Fuse Blocks Blade Fuses And Accessories Circuit Protection - Waytek Wire
sbreadner
Nov 25, 2012 01:11 PM
brkncly
6.4L Power Stroke Diesel
Sep 15, 2012 09:47 AM
mattisjd
1983 - 2012 Ranger & B-Series
Oct 13, 2004 09:56 AM
rudy84
Feb 13, 2004 12:32 AM
hockey101
Electrical Systems/Wiring
Jan 25, 2004 06:28 PM
