V10 vs. PSD comparison. WITH VIDEO!
#61
It still amazes me how well these trucks handle that amount of weight! I'd LOVE to try pulling 16K lbs!!!
#63
#64
Matt, your '06 as well as the '08+ trucks in our configuration are rated for 23,000 lbs GCWR.
Subtract our ~8,000 lb trucks would leave around 15,000 lbs 5th wheel capacity. Only 12,500 for conventional trailers with a WD kit, like we had on Sunday. We were safely within our limits.
Mike's and Andrew's trucks, however, are rated for 10,000 lbs trailer weight and 20,000 lb GCWR.
#65
I have two. One is a 97 f250, reg cab, manual, 4.10 gear, 7.3. The other is a 2000 f250, reg cab, manual, 4.10 gear and 5.4. Neither of them has problems like the 7.3 in that video had. If I had that much trouble pulling out from a stop with a load like that then I would be hurting, because there are plenty of red lights around here mid-hill on at least an 8-10% slope.
Here is a picture of my truck in my parents driveway. Halfway up the hill going to their house. Me stopped on the hill. People routinely back out of their driveway and stop you on that hill(bunch of 80 year olds that take 10 minutes to pull out lol).
#66
Wow, looks like quite a hill!
How much weight do you normally pull? I know that the 7.3L engine we pulled with had 250 HP stock. I also know that for the majority of the pull we were very close to the peak HP RPM. And it did 25 MPH at that RPM.
My truck had 100 more horsepower, and like the 7.3 completed the majority of the hill at peak HP. And it did it 10 MPH faster than the 7.3L truck. This sounds right to me.
Sounds to me like either we had a few more pounds behind us than you normally do, or that your truck is NOT stock. Or my '08, Matt's '06, and Andrew's '01 weren't running right.
But seriously, if we can get together and do this again you're more than welcome to come and play! We'd love to throw an OBS truck in the mix!
#68
How much weight do you normally pull? And it did 25 MPH at that RPM.
You see the camper in the first picture? That is the smallest trailer I pull and it is a 26' that weighs ~6k lbs. I used to pull trailers upwards of 15k lbs, but now the heaviest I pull is about 10k. Parking that camper is fun too. I can't pull it in forwards because the back bumper drags going from the road to the driveway too bad, so I have to back it up the driveway. Notice it is touching a tree on the side you can see. It's touching another tree on the other side too. Makes for a tight squeeze lol.
I'll pop the hood or let anyone check my truck any way they want to to verify that it is stock. The only mod that it has is a k & n air filter. Still has the cat, stock downpipe and exhaust too.
Next time I am up near Cincy I will definitely let you know.
#69
#71
Originally Posted by FTE Specifications
The 7.3L Power Stroke® turbo diesel V-8 produces 250 horsepower (15 more than last year) and 505 lb.-ft. of torque with the automatic transmission, and 275 horsepower and 520 lb.-ft. of torque when joined to a manual transmission (late availability).
It could have used a few more! Would have been very curious to try that hill chipped!
#73
#75
