New Truck is Missing
Old Apr 11, 2010 | 09:20 PM
1999SuperDutyStroke's Avatar
1999SuperDutyStroke
Hey guys as most of you know i recently bought a 2000 Crewcab Lariat 209xxx miles. When i brought it home the WIF light was on. I checked and changed fuel filter, and drained the fuel bowl. It had a slight miss in it when i got it. But after pouring the sea foam in the WIF light went out.
However the miss is still there. Cory hooked it up on AE, all my numbers were good except the ICP pressures were fluctuating. EVerytime the numbers would fall the miss was more noticeable. I swapped the ICP sensor from my truck to hers and it didnt change anything. While driving it at half throttle, you cant feel it, when i let off a lil bit you can feel it again. Does anyone have any suggestions or thoughts of possible ways to fix it?!?!?!?!
Old Apr 11, 2010 | 09:29 PM
Tenn01PSD350's Avatar
Tenn01PSD350
What all did you check with AE? Contribution test or rotational velocity OK?
Old Apr 11, 2010 | 09:35 PM
1999SuperDutyStroke
Cory would know more about what he checked. However i remember him running the contribution test aswell as buzz testing the injectors.
Old Apr 11, 2010 | 09:50 PM
Tenn01PSD350
Hmmm...I'm sure if he saw something amiss he would have said something. Have you had a chance to pull the VCs and torque check the injectors and valvetrain? Also might want to pull the oil filler cap and see what comes out of there while running. What the heck, swap out your CPS too while you're farting around since it is so easy to do.
Oh, and make sure that goofy tin nut is tight on the IPR which you may consider swapping out since you have two of those now.
Old Apr 12, 2010 | 05:00 PM
1999SuperDutyStroke
Mike thank you for the suggestions, I havent had a lot of time to check much on it yet. My truck is back in the tranny shop for an annoying lil ship that has recently reared its ugly lil head, its still under warranty and i want it to be taken care of first before i start tearing into hers.
Old Apr 12, 2010 | 05:06 PM
megawatt00's Avatar
megawatt00
Ya gave me a heart attack Ray I thought this was another "stolen truck" thread. Mike gave you the same advise I was going to give so no use in repeating it.
Old Apr 12, 2010 | 05:12 PM
1999SuperDutyStroke
Lol i didn't even really think about that!!!
