429 Sneeze/backfire???
Old Apr 10, 2010 | 10:10 PM
Powerstrokin_350's Avatar
Powerstrokin_350
I have a 429, very mild build, almost stock. Just finished a resto and am now tuning the truck for the street. I can not get it to run good, it idles nice, but it has no power at all. I also can not get it to stop sneezing, sputtering, backfiring through the carb when giving it heavy throttle. I tried tuning the timing from 0 degrees to around 25 btc, currently around 10-15, tried the vac advance but dont know what im doing tuning in there. Had a holley 750, switched for a edelbrock 600, both did nothing. Have not found any vac issues, running out of ideas. Thinkin screw the old tech, moving towards using a 12 valve cummins. Any ideas???
Old Apr 11, 2010 | 01:09 AM
Bear 45/70's Avatar
Bear 45/70
Timing chain jumped.
Old Apr 12, 2010 | 04:52 PM
bigdan1979f-250's Avatar
bigdan1979f-250
Are you using on old distributor? Has it been a while since you changed the cap and rotor? I have a 390 and it did the exact same thing until I changed them.
Old Apr 12, 2010 | 06:28 PM
Powerstrokin_350
Its actually a brand new dist/cap/rotor. I do think I will be pulling the timing cover off to inspect the timing chain/timing marks. But I may try a different distributor first as I have 2 460s on the shop floor that run that I can pull the dist out of.
Old Apr 12, 2010 | 06:41 PM
phatjack81's Avatar
phatjack81
Could the vacuum advance hose from dist. be hooked to a manifold vacuum and not a port above the throttle plates.
Old Apr 12, 2010 | 07:31 PM
Powerstrokin_350
I checked that and its hooked to the vac port on the carb for the dist, and the timing light shows that difference when hookeod/unhooked
Old Apr 12, 2010 | 08:07 PM
Bear 45/70's Avatar
Bear 45/70
Ported vacuum nipple should have "NO" vacuum at idle. If the timing changes between the hose being connect and not, then you are on the manifold vacuum nipple and no the ported vacuun nipple.
Old Apr 12, 2010 | 08:17 PM
Powerstrokin_350
Oh? well I am on a edelbrock 600 carb, with a fitting on the drivers side/ pass side of the FRONT of the carb. What one to use???
Old Apr 12, 2010 | 09:40 PM
compman25's Avatar
compman25
Use the higher up port of the two, I believe it is the drivers side port on an Edelbrock carb.
Old Apr 12, 2010 | 10:16 PM
Bear 45/70's Avatar
Bear 45/70
But if the nipple for the ported vacuum has vacuum on it at idle the carb is adjusted wrong.
Old Apr 14, 2010 | 11:59 AM
rotun's Avatar
rotun
Reads ***** rules!
The manual for my 91 shows the vac. line should be disconnected while setting the timing, don't know if this will help but here it is anyway.
80ford100
Feb 4, 2015 06:58 PM
bigcountry1009
34
Jan 13, 2015 05:18 PM
bigcountry1009
Nov 12, 2014 11:09 AM
91-F700
Jun 30, 2014 04:41 PM
dino
21
Dec 18, 2005 10:30 PM
