Need help with fuel filter
Old Apr 10, 2010 | 08:14 PM
gator71's Avatar
gator71
I have a 1996 f150 5.0 try to change the fuel filter today bought the tool to change it with. Slip the tool into the fuel line fitting and still could not pull off the fuel line.
Old Apr 11, 2010 | 12:07 AM
94MustangGT's Avatar
94MustangGT
It can seem like a hat trick at times, but it should come off after a minute or two. Once you get the tool completly in the fuel line fitting, try working it back and forth and releasing some pressure at the same time. Good luck.
Old Apr 11, 2010 | 06:20 AM
TexasGuy001's Avatar
TexasGuy001
Which tool did you get the metal or the plastic ones? I have found that the plastic ones work better for this task. You could also try spraying some penetrating oil on it like PB Blaster.
Old Apr 11, 2010 | 07:44 AM
SaikotikGunman's Avatar
SaikotikGunman
Just don't force it... The retaining clips for mine came out in pieces. I wasn't the first person to have done that, though, because not enough pieces came out to account for both full clips.
