I have already searched and read about 2x4 to 4x4 conversions.. and they are well and good if you wanna do a body swap. My question is though, if you have a 65 with i-beams, what all needs to be done to convert it if you have parts from a 79 f150.
I would assume the whole steering system, would need to be replaced, the radius arm drop brackets, but what about the tranny.. It's a NP 4 speed.
The only two other problems i could see would be pumpkin clearance and coil tower spacing....
Reason: spelling
So Bill... Would you foresee any logistical problems? I'll measure my perches tomorrow, but just curious now. I live very very rural in western nevada... 2 wheel rat rod isn't exactly practical. And I would like to enjoy my truck more.
YES.
your crossmember will have to be removed, (then where will your engine perches mount?) your coil spring buckets are not correct, your frame does not have front shock mounts for the 4x4 front end, your radius arm mounting brackets are in the wrong location's you would need to install a 4x4 front crossmember, your steering box will not be in the same place.
Q: do you have the whole 79 truck or just the front end?
this is the reason most people do a frame swap to have 4 wheel drive with a slick body..... unless your lucky enough to have an original one,
i would do a frame swap.
a quick search found this pic of a 4x4 frame to show you what you would have to do to your frame.... lot's of work!
FE352, We really could give a big rats azz how you swap things on your truck. Peeps come here and ask, we try to help.
Cab/front clips have 6 mount points that are the same between the years. While lifting the cab/front clip look huge it is not. Beating your head against a brick will wall will draw blood, we are advising against that. You are putting your life and maybe someone else's in harms way should you not get your swap done correctly.
Bolting the sheetmetal on a different chassis is much easier and safer.
Jophn
Well way to be a dick about it.. It's not like I'm asking what tire size I can fit. This an actual technical question. It might not what you would view as practical, but then again, nothing about owning a truck that is older then time is. It also isn't like I joined, just to post this thread, I've belonged to this forum for close to 6 years. So if you wanna be crotchety go somewhere else to do it. I am not your grandchild, and would expect a little more respect.
Now the whole reason I have decided against a body swap, if I even decide any of this prudent enough to attempt is 3 fold. The truck has 55,000 miles on, the rear axle is a dana 60 with limited slip from the factory. The last but not least of my reasons is, it's my great grandfathers truck, which he ordered new to his specs.
Now I stated that I wasn't going to do it for sure, but that i was just curious. I couldn't find anything else anywhere about how to do it. Everyone just said it's easier. Nothing about safety.. But anyway. I've got my answers. Everyone have a nice day.
Now the whole reason I have decided against a body swap, if I even decide any of this prudent enough to attempt is 3 fold. The truck has 55,000 miles on, the rear axle is a dana 60 with limited slip from the factory. The last but not least of my reasons is, it's my great grandfathers truck, which he ordered new to his specs. Everyone have a nice day.
If you would have said it's your great grandfathers truck with 55xxx miles i would have said leave it alone in the first place.... you should go buy a 1000 buck beater to ride the trailes in.... and, if you have been here for 6 years you should know by now that Jophn is the way he is to get a point across. dont let him rub your skin like 60 grit. just sayin
Look BOY, you need to put your little pee pee back in your pants and stop with the name calling and trying to **** on my shoes. You can be just as damn hard headed as you want to be, I don't care.
You go ahead and do it your way and I hope it goes well and you don't kill someone because your half azz upgrade attempt comes apart.
I have to agree with garbz2. This is a not a hard swap if you have some fair fabricating skills. You can upgrade with aftermarket coilovers and radius arms pretty cheaply since you are changing mounts.
