I-beams installed
Old Apr 10, 2010 | 11:38 AM
santi2322's Avatar
santi2322
I-beams installed
Well I finally got my DJM dropped I-beams installed. It took me longer then expected but hopefully when the slick is all put back together it will look good. Also, here's a lesson learned- If you have the Radius Arms on the truck, do not try attaching your I-beams to the Radius Arm before attaching the I-beam to the frame. Here are some pics of what I got so far:
Old Apr 10, 2010 | 11:40 PM
jmf66's Avatar
jmf66
Looks really good! I just did that a few month's ago so I know where you're at. That blue looks to be the same original color as mine, although someone has since painted it some sort of purple. I don't see rust holes on the cab... that's a good thing!
Old Apr 11, 2010 | 08:50 AM
dman2008's Avatar
dman2008
Did you put in new springs? If you could when you have it back together let us know how many inches it actually drops it? Nice work looks great too.
D
Old Apr 11, 2010 | 09:30 AM
santi2322's Avatar
santi2322
jmf- yeah the only rust spot is on the tailgate and there was some on the rad support.
dman- I didn't use new springs but I was thinking of getting new ones. I'm still in the process of getting everything else installed and fixed but I will see how many inches it actually dropped. The wheels really bow out right now but I guess that's because there is no weight with out the engine in.
Thanks for the compliments!
Old Apr 12, 2010 | 09:09 AM
jmf66's Avatar
jmf66
Right now, the best deal is on Moog springs through Amazon. I got the Moog CC308 variable-rate springs shipped to my door for $73.
I replaced the stock ones after I had rebuilt the front-end and had everything back together... it's pretty easy the 2nd time with the engine out and the bolts coated with anti-seize.
Old Apr 13, 2010 | 09:25 AM
tschmitt's Avatar
tschmitt
Looking good, keep up the great work!
Firewood Bandit
Jan 30, 2017 09:29 AM
richdawg
139
May 24, 2016 08:10 AM
BEARDOWN
Jan 5, 2015 05:09 PM
texaskid22
44
Dec 6, 2012 08:56 PM
1977f150xlt
Testing.....
21
Aug 18, 2009 06:47 PM
