2001 Conversion Van Shock Absorbers
Old Apr 10, 2010 | 02:07 AM
Ekkehard's Avatar
Ekkehard
Need to replace the shocks on my 2001 E150 Conversion van, tried stock but without success. Stock pre-1999 are too soft, stock 2001 "handling package" are too stiff making the van shake badly. Have to mention that the van runs on 16" 265 tires.
Anyone that runs a conversion van on aftermarket shocks? Any recommendations?
Thx /ekkehard
Old Apr 10, 2010 | 07:19 AM
gearloose1's Avatar
gearloose1
You probably have to deal with worn springs first.
Plus.. those are huge tires --- which mean more stress on the front end.
Check for worn u joints, tie rods, etc. first.
Old Apr 10, 2010 | 01:03 PM
Fox Fader's Avatar
Fox Fader
Try the KYB's, they are suppose to take up the slack from warn parts w/o being to stiff.
Old Apr 10, 2010 | 08:43 PM
rebocardo's Avatar
rebocardo
Well, my van is very heavy (4x4) and I put on dual Ranchero RS5000 shocks. You can download the catalog and match up a shock to match your mounting points and go from there. You can get them with different valve rates etc.
Old Apr 11, 2010 | 02:03 AM
Ekkehard's Avatar
Ekkehard
Maybe the E150 Clubwagon is the closest you can get to a Conversion van, with regard to weight and ride comfort requirements, could these shocks be suitable? Is the clubwagon a heavier vehicle than the standard van?
Old May 9, 2010 | 01:13 AM
Bbasso's Avatar
Bbasso
I just put in Bilsteins... LIKE WOW!
they are just wow.
I like and would recommend.
A little on the pricey side, but from everything I heard/read they will out last and out perform all others.
I have a E350 PSD, extended.
cwheat1202
18
Oct 29, 2025 06:53 AM
Shortems
All Things Towing
24
Jan 30, 2016 04:40 PM
Ekkehard
2009 - 2014 F150
Jan 24, 2016 07:33 PM
Ekkehard
Oct 13, 2009 02:06 AM
jbjerke
Sep 5, 2004 06:08 PM
