for 302
Old Apr 10, 2010 | 05:21 PM
gerry0011's Avatar
gerry0011
no i paid 200 bucks for it i m not to worried i was told mustand block where 4bolt main. but it is a stock carb 302 outta an early year mustang
Old Apr 10, 2010 | 05:34 PM
nflfreak43's Avatar
nflfreak43
you got screwed. i can find 302 Blocks left and right all day for 100 bucks or less. and these are in good shape.
Old Apr 10, 2010 | 09:11 PM
gerry0011's Avatar
gerry0011
i bought the whole truck for 200 buck and i m usung the box sides and other parts
Old Apr 10, 2010 | 09:13 PM
gerry0011's Avatar
gerry0011
next question whats the best way for headers ? rgw oxygen sensor is at a weird spot
Old Apr 10, 2010 | 11:00 PM
Conanski's Avatar
Conanski
Not sure what your question is...
Old Apr 11, 2010 | 06:58 AM
gerry0011's Avatar
gerry0011
i would like to put header on the truck its a 93 bronce that is fuel injected, but my problem is the oxygen sensor is in the y pipe right before the pipes meet i dont know if this makes sense but the a mini H pipe that goes from one side of the y pipe to the other and the oxygen sensot is in the midle of the H pipe .its kinda hard to explain
Old Apr 11, 2010 | 07:02 AM
lew52's Avatar
lew52
Just put the sensor in the right side pipe right after the collector , it will be fine ....Lew
Old Apr 11, 2010 | 07:27 AM
gerry0011's Avatar
gerry0011
and it wont afect anything i was told if i did that i would become a bigger pig on gas . cause it wasent getting the reading from both sides and would think its running lean nd call for more gas
Old Apr 11, 2010 | 07:37 AM
lew52's Avatar
lew52
My truck just reads from one side & works fine , as long as you don't have any other isues it shold be fine . I use an H pipe after the headers but its to far down steam to get a good reading , so my sensor is in the right pipe just after the collector.....
Old Apr 11, 2010 | 07:43 AM
gerry0011's Avatar
gerry0011
ok sweet...did it make a big difference in fuel millage?
Old Apr 11, 2010 | 07:48 AM
lew52's Avatar
lew52
I don't know , i went from a stock 5.0 to a hi performance HO , so milage wasn't a concern.......Lew
Old Apr 11, 2010 | 07:49 AM
gerry0011's Avatar
gerry0011
ok thx its no that much of a consern for me ether but i still would like to know
Old Apr 11, 2010 | 09:27 AM
  #28
Conanski's Avatar
Conanski
I have been running longtubes on my past two trucks with a single O2 in the passenger side collector with no problems. I installed a second sensor in the drivers side this past year just to see if it would make any difference and it didn't so I took it out again.
If you use shorties they often come equipped with an O2 bung, and the Y pipes from Flowmaser and Bassini have them as well so you have lots of choices.
Old Apr 16, 2010 | 09:08 PM
  #29
gerry0011's Avatar
gerry0011
do erly 90"s 2 wheel drive trucks and 4 wheel drive trucks have the same exhust manifold?
Old Apr 16, 2010 | 09:21 PM
  #30
Conanski's Avatar
Conanski
Yes they do.
