EGR
Old Apr 8, 2010 | 06:32 PM
twister2gt's Avatar
twister2gt
EGR
The previous owner of my truck took all the smog stuff of the truck and left the EGR sucking air straight in. It makes a noise that is kind of annoying when it starts to suck in air. Can i cap it off or should i run a hose to it and put a small filter on it?
Old Apr 8, 2010 | 06:35 PM
SlowNSteady's Avatar
SlowNSteady
id cap it, i guess you could also put a small filter on it. whatever you do i wouldnt leave it just open to air. you also could cap the vacuum line that makes it open, that would be another solution.
Old Apr 8, 2010 | 06:41 PM
twister2gt's Avatar
twister2gt
oh now i figured out why it hasn't made the noise since i got the truck i replaced all the vaccum lines that i had capped off. looks like i need to cap that one.
Old Apr 8, 2010 | 06:52 PM
SlowNSteady
if it has a egr position sensor, itll set a check engine light, but it seems that wouldnt bother you anyway.
