Engine fit in?
Old Apr 8, 2010 | 06:30 PM
Wicked Endings's Avatar
Wicked Endings
Engine fit in?
Will this engine (351 Windsor A4AE-6015-AA 6) fit into a 1985 F150 Two door, two wheel drive, C6 transmission truck?
What about this engine? Stock 1971 351 Cleveland
Anyone know?
Thanks!
Old Apr 8, 2010 | 08:20 PM
Chitownhillbilly's Avatar
Chitownhillbilly
Windsor drops in, and was available in your truck.
Cleveland will fit but will take more work and fabrication, as it was not available in your truck in the US.
Old Apr 8, 2010 | 08:43 PM
ctubutis's Avatar
ctubutis
As Chitown mentioned, yes, the 351W was offered in your truck in that year and will fit. A
C6 can fit, too, but you need to get one with the bell housing pattern used by the 351W.
You'll also need to pay attention to what are referred to here as "engine perches," they're
basically brackets attached to the frame rails onto which the motor mounts are bolted; if
you're switching from a 6-banger to a V-8, you'll have issues.
Old Apr 8, 2010 | 09:09 PM
Chitownhillbilly
I think he already has a C6 mounted to his 300, which has the small block bell housing.
And by "issues" you just meant he'll have to switch perches right?
Old Apr 8, 2010 | 09:22 PM
ctubutis's Avatar
ctubutis
Hmmm... Guess I read through it too fast and missed that, sorry.
Yeah, that'd be all.
Old Apr 8, 2010 | 09:44 PM
Franklin2's Avatar
Franklin2
Remember if you get a 351w from a car, 99% of the time you have to change the oil pan to a rear sump to fit these trucks.
Garrett Murta
Sep 12, 2016 07:40 PM
BAKAFLAKA
Engine Swaps
Oct 13, 2015 12:12 PM
Eli1644
Mar 3, 2014 04:55 PM
Eli1644
16
Jan 5, 2014 12:48 AM
DanMan7
13
Aug 28, 2004 12:51 PM
