Transmission question
Old Apr 8, 2010 | 05:32 PM
83fordcolebrook's Avatar
83fordcolebrook
Exclamation Transmission question
Hi my names Austin and im new here. I have been rebuilding my 1983 ford f-150 stepside. It is almost done. I took it to have a tranny filter change, and flush, because it would not shift out of second gear. When they went to change the filter they found pieces of the clutch and friction plates in the bottom of the transmission pan. What does this mean for the transmission? Do i need to have the whole thing rebuilt, or is it that i simply need to replace the clutch and friction plates? Im hoping it is just something simple, but afraid i will have to rebuild it and im running out of money, and patience. any help would be greatly appreciated.
Old Apr 8, 2010 | 07:42 PM
Rogue_Wulff's Avatar
Rogue_Wulff
As long as the trans works, don't worry about it. When it quits, then it's time for a full rebuild. Changing the clutches/friction plates requires complete trans disassembly.
This a C6 or AOD? If it's a C6, it might go another 1/2 million miles........
Old Apr 8, 2010 | 08:14 PM
83fordcolebrook
the problem is that it doesnt go above 20 mph, and its going to be my daily driver. I will be needing it to get to work this summer.
Old Apr 8, 2010 | 08:56 PM
ctubutis's Avatar
ctubutis
You might start shopping around for a replacement transmission.
Old Apr 12, 2010 | 09:56 PM
83fordcolebrook
yep found one for 300. now just have to swap them out and hopefully everything will be ok now.
Old Apr 12, 2010 | 10:10 PM
FordNFishinLover's Avatar
FordNFishinLover
good luck.
Old Apr 17, 2010 | 10:58 AM
83fordcolebrook
well i got the old transmission and transfer case last night with some help from my buddy, i also got the new transmission yesterday, so it is going pretty good so far.
