need some help
Old Apr 8, 2010 | 03:34 PM
hotter69's Avatar
hotter69
need some help
ok i did the vin decoder but it didnt tell me much. i want to know the axles ratio's, if it has a posi, how many of trucks did they make with theses options, stuff like that. here is all the info.
my truck is a 1966 ford f100 factory 4x4 long bed stepside, it has a 352ci, np435 tranny dana 21 t-case, dana 44 front, and ford 9" rear
the vin is f11yk734964 then all these #s are below it
129f f110 k81 a08
05600 172 4000 75
if you know how to figure this out i could really use the help thanks
Old Apr 27, 2010 | 08:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hotter69
My truck is a 1966 Ford F100 factory 4x4 long bed Flareside. It has a 352ci, NP435 tranny, Dana 21 t-case, Dana 44 front, and Ford 9" rear.
F11YK734964 129 F F110 K81 A 08 05600 172 4000 75
F11 = F100 4WD.
Y = 352 2V.
K = Kansas City Assembly Plant.
734964 = 1966, assembled August 1965.
129" Wheelbase.
F = Arcadian Blue.
F110 = F100 4WD, 5600 lbs. GVWR
K81 = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
5600 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from.
