Torque specs. and pattern for 7.3.....
Old 01-27-2003, 04:50 PM
toddjlyons's Avatar
toddjlyons
toddjlyons is offline
Can anyone here tell me what the torque settings and pattern is for a 7.3 diesel? Thanks! Todd J.
Old 01-27-2003, 06:01 PM
alanscott's Avatar
alanscott
alanscott is offline
I think you might have to be a bit more specific, like head bolts, water pump bolts etc.
Old 01-28-2003, 07:57 AM
toddjlyons's Avatar
toddjlyons
Man, I feel stupid! I need to check what I write from now on! What a first showing on my virgin post! Anyway, head bolts. Todd
Old 01-28-2003, 02:51 PM
HTRDDSL's Avatar
HTRDDSL
HTRDDSL is offline
Out of the book
Cauton: Do not use too much engine oil on the threads of the cylinder head bolts,or damage to the threads and poor sealing can result. Do not use anti seize compounds,grease or any other lubricants except engine oil on the cylinder head bolts threads because they will affect the truce torque value reading of the bolts
Tighten the bolts in sequence, shown in 3 stagesStage
1. Using the first sequence tighten bolts to 88NM(65lbFT)
2. using the 1st seuence tighten the bolts to 115 Nm(85lbFT)
3. Using the 2nd sequence tighten the bolts to 129NM (95LBFT)
Sequence
in the center of the head upper is#1 below is 2 then from there go counter clock wise
Sequence #2 start on the bottom rear bolt work your way forward in rows the last bolt will be upper inside bolt closest to the front of the motor
Old 01-28-2003, 04:08 PM
toddjlyons's Avatar
toddjlyons
Thumbs up Torque specs. and pattern for 7.3.....
Thanks!! TJ
Old 01-28-2003, 08:24 PM
HTRDDSL's Avatar
HTRDDSL
HTRDDSL is offline
Your welcome
Old 10-13-2003, 03:50 PM
Wellcraft's Avatar
Wellcraft
Wellcraft is offline
7,3 Torque specs
Do you have specs for the flywheel as well???
junkyardjeff
12-12-2016 09:13 PM
aaroncronin
General Diesel Discussion
09-18-2016 12:35 PM
ihf-350
Ford Truck Parts for Sale
09-12-2015 05:00 PM
Chris 73
04-28-2006 08:50 PM
DannyP
03-23-2004 09:43 PM
Quick Reply: Torque specs. and pattern for 7.3.....
