NOS on PSD
Old Jan 27, 2003 | 04:40 PM
Nate9982's Avatar
Nate9982
NOS on PSD
what do you guys think about installing Bully dog's NOS kit? How hard is it on your engine compaired to propain and how much life does it take from your truck.
Any input would be great.
Old Jan 27, 2003 | 07:02 PM
HTRDDSL's Avatar
HTRDDSL
NOS on PSD
Running NOS is safer in most aspects the running propane,
Reasons being is that NOS is a type of oxygen and Diesels like air you can never run a diesel to lean with NOS and if it does it will just stall, As for Propane I have ran propane and NOS for years on my PSD Propane first then NOS, Propane acts as a catalist it will burn more #2 fuel when running it The problem is that it is really hard on your bearings and if it is not introduced correctly you will get detation and thats a real bad thing Although propane is cheaper in the short term it will cost you a motor in the long run if used inncorrectly
When we pulled my motor out and looked at it every rist pin and bearing had serve ware on it due to the high amounts of propane
The call is yours
Old Jan 28, 2003 | 10:40 AM
Nate9982's Avatar
Nate9982
NOS on PSD
With that said, it seems like NOS is the way to go. I would much rather pay the extra money and get a product that will not drastically reduce the life of my engine. Ok so lets say I installed NOS on my truck, will the trany, driveline and rear end take the extra HP. I have already istalled a aftermarket clutch by LUK, AFE intake, and 80hp microtuner from superchip.. Thank for the great input.
Old Jan 28, 2003 | 12:07 PM
HTRDDSL's Avatar
HTRDDSL
NOS on PSD
Nate9982,
I take it that you have a Stock replacement clutch with the updated throw out bearing and pilot bushing?
I will tell you I went though 13 clutches in 2001 The only one that really heald up was a custom built on from Peter at SBC.
I have sence replaced the trans and went to a auto I did the complete conversion and put in a BTS trans, By looking at the truck now you could never know I had a 6spd in it other the running the vin plate, I would highly recomend looking into another clutch you will soon find out that the LuK will not hold, It also depends on how much HP you are putting to the ground too.
if you are around 420HP at the wheels think about a dual disc clutch, Running 420HP on the ground is a huge amount of HP keep that in mind.
I only know of 3 people that trulely have that on the ground, and only of 2 that have it with #2 alone
Old Jan 28, 2003 | 06:50 PM
Thunder266's Avatar
Thunder266
NOS on PSD
3 people Eh.... LOL Hey bryan
Nos is the better way to go over propane IMHO.Unless you are never going to put high flow injectors in. Thunder
