Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Good and bad
Old Apr 7, 2010 | 11:44 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Good and bad
Well, I'm finally installing my intercooler! Got it in yeterday, actually. Still have to do all the piping and my new Ford Racing boost guage. I'll keep you posted and get some pics up as well.
As for the bad, that bad injector got worse. Am in the process of finding another one to swap parts on...... Jim at Rosewood diesel may be supplying a core for the procedure. Hope so. Oh well, back to work.
Old Apr 8, 2010 | 06:28 AM
96sherm's Avatar
96sherm
you keep this up and eventually it won't be street legal Dave...
Old Apr 8, 2010 | 10:37 AM
Fullcrew7.3
That's a scary thought! And one of these days I'll actually get to show it to you guys as well. As long as it's still legal that is!
Old Apr 8, 2010 | 11:42 AM
Fomoko1's Avatar
Fomoko1
I see rapid tire wear in your future Dave!
My 92 F250/7.3 has a drain back problem, if it sits for afew days I have to bleed the fuel system. I`ve been told that it`s likely the mechanical fuel pump check valve causing this. Any thoughts there Dave?
Old Apr 11, 2010 | 09:30 AM
Fullcrew7.3
I'd think that's likely the problem, but I'm no expert. Is that right in the pump or a separate unit? You could just install an inline check valve if it's easier that way??? Not real familiar witht he IDI's.
Old Apr 11, 2010 | 11:33 AM
Fomoko1's Avatar
Fomoko1
I`ve been told it`s likely the lift pump. Putting in a separate inline check valve sounds like a good idea.
Old Apr 11, 2010 | 11:56 AM
preppypyro's Avatar
preppypyro
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
A TON of information there!
Old Apr 11, 2010 | 11:09 PM
Fomoko1's Avatar
Fomoko1
Thanks, I should have remembered that.......I will check it out.
Today, after sitting for afew days, the 92 fired right up. Possibly when we changed the fuel fuel afew days ago that fixed the problem. I had that same thing with my International diesel truck years ago, after changing the filter the problem went away.
Old Apr 12, 2010 | 07:48 AM
Fullcrew7.3
It could have been a weak spot (or 2) in your fuel line. My '87 Nissan diesel had exactly the same problem. And like you say, after replacing the line, it started. Glad to here it! I just got a reply from Rosewood diesel and Jim said he's hoping to get my injector built for me this week. He's the guy I got the stage 1's from back in '07.
Old Apr 13, 2010 | 10:01 PM
Fomoko1's Avatar
Fomoko1
It seems to be ok now tho now there's an oil leak in the rear main seal.
Old Apr 14, 2010 | 09:32 AM
Fullcrew7.3
There's always something.....
Old Apr 14, 2010 | 11:44 AM
Fomoko1's Avatar
Fomoko1
So far I`ve got quotes from about $750 to $1,000.
I don`t have a hoist and a transmission jack so pulling the motor back out might be the only way but that`s a lot of work and time.
