General Automotive Discussion
Dodge Intrepid Trouble
Old Apr 5, 2010 | 06:29 PM
Loopy's Avatar
Loopy
I was hoping I could find a little help on this section with my 94 Dodge Intrepid. It has a little over 173,000 miles and I've had it since 94. It usually starts and runs great.
Here's the problem: The car starts flawlessly cold. After it heats up awhile and then is turned off it will not start. After it cools off for about 15 to 30 minutes it will usually start.
What I've replaced: Cat, it needed it anyway. Cam position sensor last year when the check engine light came on and had a similar starting problem. The fuel and air filter and pcv valve last week. Anyone have any ideas???????
The car does idle a little rough and a little below the rpm range. The temp gauge also rises slightly above where it should be. I did rplace the thermostat last fall. Although when the temp gauge does rise over, this is when it stalls or fails to start. I'm clueless.
