Door Hinge
Old Apr 5, 2010 | 03:55 PM
johndog's Avatar
johndog
Door Hinge
I have a 2002 Ford Ranger SuperCab and the lower door hinge is worn. The Sprung steel piece on the body hinge is worn through. Has any one replaced this? I did a quick search and can not find the part number. Only found the door hinge not the body part that it fastens too.
I realize the piece is ribited to the hinge but could not find the hinge assembly either.
Don't see any damage to the nylon wheel and the door itself seems good at the pins.
Could just crawl out the passenger side but too old and fat for that
Old Jun 2, 2010 | 07:20 AM
g_k50's Avatar
g_k50
Did you check with your local Ford Dealer Service to see what they would suggest?
Let's bump it and see if someone jumps at the correct answer.
