tranny swap
Old Jan 27, 2003 | 12:02 PM
87black150's Avatar
87black150
tranny swap
I've got a 87 4x4 F150 302 with the TOD tranny. I was thinking about swapping trannys for something thats geared lower. I need the lower gearing for towing. I've got the 8.8 rear with 3.55 gears. I want to know what trannys I can swap to without major modifications. I was thinking about something with the granny gear. All opinions appreciated. Thanks.
Old Jan 27, 2003 | 12:11 PM
steve83's Avatar
steve83
tranny swap
The only manual OD with a true granny 1st is the ZF S5-42, and it's EXTREMELY expen$ive and hard-to find (especially 4WD)because it's so popular. It was offered in '87, so it'll be fairly easy to bolt in, but plan on spending $800-1200.
Any full-size Ford truck transmission from '80-96 from a 4.9L, 5.0L, or 5.8L will fit and bolt up in place of your current one, but there were minor variations in clutch linkage, shifter location, t-case linkage, overall length, and crossmember location. You may have to move your crossmember, cut your floor or change the adapter plate, and cut your driveshafts.
87diesel
Jul 22, 2013 09:10 AM
luv2huntnfish
Engine Swaps
Sep 3, 2012 09:22 AM
.87-ford
Jan 11, 2011 07:29 AM
bryan_h6121
Jan 10, 2005 09:16 PM
